double. on mine. i had a Antirock for my FJc. the TK1 is betterThe TK1 is about 100 less than the Antirock, did you go with single shear arms ? I am measuring for width & arm length now.
Pick up your telephone and use it for more than taking selfies and talk to themThank you, the double shear arm doubles the price. Also, the TK1 site does not show a bent arm ? or the single shear for that matter.
I’m sure I’ve seen the bent arms on the site before but can’t find them for the life of me now. I had a pretty tough setup because of the way I built my coilover mounts so I fabbed my own bent arm. Had to buy a third arm and cut it in half. Happy to share more if you want.Thank you, the double shear arm doubles the price. Also, the TK1 site does not show a bent arm ? or the single shear for that matter.
I beleive the spines are deeper than the arm is wide, so there is no standoff. The little colored cap on the end is up against the end of the shaft as well as against the arm. @DangerNoodle has had some trouble with loosing those caps, bolts coming loose or breaking and installed a better bolt in the end. I drove over a thousand miles before I even loctited anything at all with no problems.Could you measure the width of the TK1 arm at the splines & when assembled does the inside edge of arm line up with where the splines end ? trying to determine where the arms line up in relation to the splines, it looks to be about straight off. if they are pushed outboard at all it will rub tire at stuff.
