hello, first off would like to say, i haven't been on here in a very long time, and thanks to everyone for the info, and my login even still worked. i am grateful!
so to my question: i have a 78 FJ40(in pieces at the moment), i am going to build a link suspension front and rear for it, to attach to rockwell axles. i am debating on using a 4 link using the bracket to attach to the top of the chunk, or doing a 3 link that would have the upper 2 links tie together before attaching to the bracket centered over the chunk. my initial thought is that it would still flex well, and hold the axle centered without a trac bar. has anyone done this? if so, does it work well? i have 1.25 inch heim joints with high misalignment spacers i bought a few years back when i started this project...
isn't quite ready yet but I predict more awesomeness ;p Those are both softcore rigs anyway. I scavenged coil buckets from a TJ. Plan on running sway bars since you are building "high". I'd mount the coils outside the frame for sure. Are you tubing out the rear? The rear coils may be too close to your tires so you may need to chop the frame. Plan on, at least, 6" lift coils. I assume you'll be running 44's or larger?
Post up some pics already ;p
