Lights on dash, ideas?
Michigan
Gents,
While driving down freeway:
- “P” light indicator started flickering, so that “D” and “P” were coming on at the same time.
- Then “P” went solid along with “D”, and then I got 3 more lights:
1. Check engine
2. Vsc Trac
3. Vsc off
No apparent change in driveability, just pulled off to a gas station.
2006 LX470 325k all up to date.
Ideas?
Mine did this two days ago. Magnetic clutch circuit code popped up. Went away after tinkering around with throttle body
I had a similar issue that would pop up after a heavy rain - once it dried out, my lights went back to normal. Turns out my aftermarket windshield was leaking. Having it replaced solved the problem.
