Lighting
Fort Campbell, Kentucky
I am having an issue with my lights in my 1970 FJ40. I went to drive it the other night and I turned the lights down to parking and then when I turned them back on they all quit working. Looking through the diagrams I can't find any kind of relay on the lights. I have looked at the fuses and none are blown. Any ideas on this issue? Can the switch be bad and cause this problem?
i have heard that sometimes the fuses look fine but they arn't [the old style kind] replace them anyways.. or my other guess is what always ends up happening to me.. there is a spliced wire that rotted out and needs to be restripped and reconnected.. check under the vehicle/in the engine bay for poorly wrapped wires, there could be a break
my hi lo beam changer some times messes up and i have to play with it to get any lights.
Yeah, I've had one of the old glass fuses fail on my for my wipers and it didnt look like it had failed. on the one I had if I looked really close I could see just a hint of discolouration on the filiment inside the fuse.
Cheers
If you can't tell by looking...put a test light to each end of the glass fuse. One end should always be hot...the other end will only be hot if the fuse is still good.
John
this happens to me where the number plate light wires go back into the cab (ambo doors) took ages to find the prob and many fues's later.
