Anyone bought Tires & Wheels in hope of better MPG? How did you make out?
The stock alloys are pretty light as is. Tire weights vary wildly. Load rating & size affects the weight of the tires. Use tirerack's tables to look at tire weights. You can see that the common 285 sized tires are easily over 50 pounds, while a 265 tire can be 10 pounds or more lighter. Going from a p-metric to a load rating of C will add a few pounds too. E rated will add even more.
