Light the way
MN physically, MI spiritually
No big deal really but I needed a project as I was getting cabin whacky. The temp finally came up a bit so I decided to put some extra light in back up mode.
This all started a few weeks ago when aI got a call from my sons friend asking if I still thought I had a tough truck. He needed a pull out of a four foot snowbank and he had been digging out got two hours with no luck. It was dark at that point and -20 and of course I accepted the challenge. When I got there he was down a 100 yard hill almost up to the windshield in snow. He thought the road had been plowed but the drift made it seem that way. I headed down locked in and realized that I really needed to back down to use the snatch strap correctly. it was than that I realized how worthless the back up light were. I backed up and turned around then backed down again kind of guessing where I was going. The snow was only three feet deep on the sides and a foot on the trail so there was not much reflection off of the snow to show the way. That's when the new project came to mind and here are the results. 50 watt ea. KC Highlighters because they are plastic, rust proof and they were $100.00 with the dash switch so they will go on when in reverse or when the dash switch is turned on. Might be good for night camp set up.
Before anyone gives the "Worthless without pictures" lecture, I know it is but it was way to cold to snap photos in the dark. Here is one of the finished mounting on my Slee bumper. I used an existing mount for the right one and fabed up a mount for the left one so it would be aprox the same height. I didn't want to drill holes in the bumper so I only had to drill one in the High Lift carrier. I don't have a High Lift jack so no big deal.
And, yes, I got him out with three tugs and up the hill we went. He was driving a Jimmy with street tires and that cost him three shots of Glenfiddich and a pitcher of Stella!
Coments welcome.
The idea is great. Could you do a write-up giving wiring details and pictures. How is the cabin switch tapped into the existing wiring? Where did you mount the switch and what does it look like? Where did you run and secure the wiring to the rear lamps?
-B-
X2 on the wiring info. I have some lights and a bunch of wire kicking around to do this project, but I have yet to decide on a plan for the wiring. I was thinking of a rear heater switch with Low = lights on while in reverse and High = lights on always. How did you do yours? I think MOT can get an OEM reverse fog light switch too!
Nice black cruiser!
OK, give me a day and I will snap some photos of the instal and the wiring. The unit comes with its own harness and relay and the switch and add on harness is an added feature that plugs right into the relay. Lamps and harness were $77.00 and the switch and harness was an extra $23.00, all from Amazon.com. The prices from other sources were from $73.00 to $177.00 for the same light units and pretty much the same for the harness, give or take a couple of bucks.
I am an idiot about electrical stuff in a car so the ready made harnesses were a real plus for this project.
And no one mentioned my Italian license plate???
Nice black cruiser!
Midnight Pearl Green. my friend...
6M1 would be Dark Emerald Pearl according to the US color charts. Dan says it is putrid green and I would have to agree. :D
-B-
I've been brainstorming about rear lights as well. I think you found a nice easy solution:)
I noticed:rolleyes:, just surprised the DMV didn't notice too:D
Photogod, you have the same reverse-light setup I have... On, Off, and w/Reverse.
I didn't think it would get these kind of responses.
Gotta be one of the best mods I've done to my truck, though. :D
I think any supplemental reverse lights are an excellent mod. About 15 years ago I installed a Hella freeform dual bulb (2 X 55w) light at the rear edge of my roof. Up high like that, it illuminates things you're working on, and a large swath of light on the ground, and also quite far behind you. You can choose how many degrees of illumination, and the light itself swivels both up and down and side to side so no matter what you're doing the light will do it. The light is extremely ruggedized as it is Hella's premier outdoor vehicle lamp and designed for massive combines and the heavy vibration of driving in fields all day/night. That's why the beam pattern is specifically set up to be mounted high and available in your choice of beam width.
It's very powerful and in 15 years and 185,000 miles it still looks like new and the original bulbs are in it. As a side bonus if anyone comes up behind you with their high beams on intentionally trying to bother you they will be so hopelessly outgunned there will be no further confrontation. Obviously this is not legal but there you have it.
Mine is set up for manual control only, but I like Photo's 'with reverse lights' wiring option. Just another lighting alternative for rear light folks.
DougM
Any pictures?
Oh, well then my apologies. Sorry...
...you couldn't find one in black! :D:hillbilly::D
Actually I love the black and I did find one just before I got this one. The black one, 1997, had only 78,000 on the ticker and the dealer wanted $19,000 for it, I offered 15 and they kept calling me back for five days trying to get the price up. I passed when my friend sold me this one, 1994, for $9,000 with 112,000 on it. I do like the black.
don't know if you wired it this way, but an easy way to do the wiring is to use a 3 position switch in which the center pole turns the relay on, the top pole is connected to the reverse light, the bottom is connected to your instrument cluster lights
That way you can turn the lights on manually (assuming your vehicle lights are on) or you can turn it off, or you can have the reverse lights turn it on/off
That's exactly how it is wired.
Photos below of the stuff.
Lights on the tire carrier and the switch in the cabin just in front of the shifter knob.
I rewired the connections and soldered and shrink wrapped them instead of the quick connect. Then wrapped them in electrical tape. I wired it all to the extra fuse panel I have in the rear, right next to the fridge. It is an easy reach to turn the switch with one finger when you go to back up. The lights are wired to go on when in reverse and also by the switch as Sandcruiser mentioned. The harnesses were a snap, just plug and play.
I ran the wires through the seal around the tailgate and nested it under my drawer system. Then ran the wires through the louvers of the rear vent and into the fuse panel. To tight for photos. Wiring diagram below. And a shot of the relay incase anyone wants to get something like it.
These are mine.
Wired to a factory defrost swich mounted in the console where the coin holders used to be. I was going to wire to my reverse switch but did not want to blind people in the mall parking lot on accident. Great work lights!!!
