Light switch logic
Long Island
So I'm installing a factory 74 harness I grabbed on eBay. I've been verifying continuity between all connections by referencing the colored wiring diagram or a 72/73 and the Haynes diagram for a 74 from coolermans website. Again, what a huge help and thank you!
My light switch with dimmer has a solid red that goes to the fuse panel for 20a headlights. Continuity confirmed. Haynes also shows this wiring connecting with the white blue at ignition. I don't have continuity between the red wire at the fuse and the white blue at the ignition. Is this correct?
As a follow up I stripped the harness down again and confirmed that the red wire does not connect in any way with a white/blue ignition. The red is relatively short and is a direct run from the light switch to the use panel. I'm going to chaulk this up to an inconsistency with the wiring diagrams unless someone can verify that the red headlight wire should tie in with the ignition.
Your Solid red is the B+ feed to from fuse box to headlight switch , it is supposed to have Constant Voltage at all times
regardless of the ignition switch key position
same goes for the green w/ red tracer stripe that is your B+ feed for your parking lights circuit
Doesn't your White w/ blue tracer stripe go from your ignition switch to the back of the fuse box as a B+ feed ?
with the rest of the large gauge wires from the ignition switch , black w/yellow , & blue w/red ?
also , what Brand or maker printing press wire diagram are u using ? and what years or year are u referencing
one last question , have u first been able to verify that your Donor harness from Ebay is indeed a 1974 and not simply
another Year by mistake ?
YAZAKI , the harness Maker did put little white parts tags on the harnesses , see if one or more is still present and what
the part#'s are post them back here and can Pro-Date it for u if u like
1908796
For a 1974 headlight, the power feed is this:
Fuse F8 gets power input from the 10ga White/Blue wire, through the F8 fuse to the 12 ga Red wire that goes to the headlight switch
1909820
Thanks guys, thats a tremendous help. I don't know if I'm over or under thinking this....The low beam is a RG wire, right? I was expecting to see this wire at the light switch. Instead the RG goes up to the column connection. The only wire going from the column connection to the light switch is the RW. Is the RW the power from the light switch to the column?
The Red/Green is the low beam but it comes from the dimmer switch not the head light switch.
It works like this: Power from Fuse F8 goes to the head light switch via the Red wire. When you pull the switch to head lights the switch connects the Red wire to the Red/White wire that then goes out to the B terminal of the dimmer switch. The dimmer is a two way toggle. It is always connecting either the Red/Green or the Red/Yellow wire to the Red/White wire. Flipping the dimmer switch causes it to switch to the other.
1910136
