Light Stalk Complete Pinout
asmara
Dubai, UAE
I'm in the middle of adding fog lights to my GCC spec LC100. I like my work to be as OEM-like as possible. Fortunately, a decent amount of the wiring, such as the relay and fuse, is in place. What I didn't have was the light stalk with the fog light switch. I bought a used one and looked at the wiring diagrams, but nothing was in one place. My replacement has a fog light switch but also the auto headlight switch which would be really easy to turn on (and turn off the headlights since there is no autoheadlight function). I looked all over and couldn't find a single source for the complete stalk pinout so I made my own. Here it is, in case it helps someone else.
edit: corrected a label, added a fog light wiring color from a later harness, and a note about the autoheadlight function.
Great idea to use the Auto function for aux lighting, I never use Auto myself. Thanks for doing the work!
Didn't even think of this. The only drawback is that the headlights would turn off, but depending on what you are running, it might not make a difference.
