lifts
hello guys i have a ?? how do u tell the size of alift that is already on a truck...the truck i got it had a lift on it and i have 33'' on it but i been looking on at some pics in differnt post and i have a lot me room from the tire to the top of the tire well..juss wanting to know how to tell what size lift i have...
Does the truck have original bumpers? Does it have slider rails? All this matters. If you measured right I am guessing it is stock apart from OME J springs. Without the extra weight of armor bumpers they will be about 4-5" of lift. His truck had lots of extra armor on it
oh i see .. okay so if i get a pic u guys can help me out because when i have seen people do body lifts they have a spacer inbetween the fram and body...
Well if there is a 1" to 2" block around 2" diameter as well as the factory rubber mounts then it has a body lift.
If it is a suspension lift the springs will look different than stock and there will be other parts added to fix the alignment after the lift.
Look for writing on the shocks
It is not a body lift NO 4-5" body lifts around. It could have 2 suspension lift and 2 in body lift.
You still did not say if it has extra weight of things like a winch bumper or not
OME Js without weight comes in at around 23.5". Now if the truck sits level then it still could have Js but also have some spacers on the front springs.
Look at where the front arms attach to the axle. There are two common approaches to caster that go there. One is a plate which is placed on both sides of the bracket and the other is bushings. If there isn't a second set of plates on the bracket then look at the arms where the bolts go through and see if the rubber bushings are either black, blue or yellow.
The other caster solution is to ad a drop bracket to the rear of the arm where it attaches to the frame. If there is one of those then you could measure how much that dropped the arm and get an idea of what is installed.
