lift question?
While I'm still contemplating exactly which direction I'm going to go.
What is the concensus on the maximum lift for a FJ40 before more modifications like cut/turn, etc are considered required?
For the last 15 years my thought has been that 6" and less are good to go without absolutely requiring modifying things to accomodate new angles.
I'm trying to decide how deep I want to dive in this time, considering going bigger.
I didn't do the cut&turn and now wish I had, if you go SOA it looks to be a necessity, just kind adepends on each application though. I decided to wait since i didn't have the cash for a CV front long travel driveline at the time. D-lines will be the most expensive part of my SOA by a long shot. Not sure how much lift I got, stock flat springs and shackle reversal plus allowance for revolver shackles. I guess it must have been plenty (prolly should've wrote down my stock measurement) because now my frame rail height clearance is 22' w/33s.
W/o cut&turn, my u-joint flanges have taken a beating and u-joints probably won't last long. But really depends on how much time you spend in 4Hi and how much you want to spend on a new front driveline.
Like haystax said it all depends on the lift and how much. I know several people that did an SOA and didn't cut and turn. But they all used stock springs that were worn. If you use after market springs you will definitly have to. A SOA will net you anywhere from 4-6" in lift. IMHO reguardless of new springs or not a cut & turn should be done, but that is just me.
Yes I think it should be done on anything over 4", your steering will be ALL out of whack, You didnt mention if you were going to do a shackle reversal? Its suggested with a SOA, Thinking about it, a friend of mine has a 2.5" lift and a SR and his steering geom. is all out of whack, He was trying to flat tow and the wheels would go the opposite dirr.
Good luck
