It's a Limited. I think the air suspension is only on the Platinum, right?
Yeah a 2015 Limited shouldn't be air suspension.
@SouthWestGA what years of Tundra coilovers fit the Sequoia?
What do the TRD Tundra coilovers have over the standard Tundra coilovers?
This is the only kit I can see that is front and rear in the $500 range. It is just shocks & struts and is meant to work with a lift but does not actually provide any lift.
Bilstein 5100 0.87-2.5" Front and 0-1" Rear Lift Shocks for 2008-2022 Toyota Sequoia
www.bilsteinlifts.com
Am I missing something?
Most problems with alignment issues are caused by the shop and specifically the tech doing the alignment. My personal experience of course. Nobody seems to know how to make the pretty lights on the machine go green (lack of trained mechanics). 3" and under lift shouldn't put you out of spec, borderline but not out.Has anybody ever run into problems with alignment after lifting the rear? My local shop stated they used to install the ReadyLift 3/2 on Sequoias, but stopped due to people kept bringing them back in for alignment multiple times per year. Said they will only install a front level only. I had pretty much settled for that and 275/65/20 tires, but just found this forum and this thread and it looks like people have had success with multiple setups, so now I'm jonesin for a legit 3" lift again - given it doesn't cause alignment problems...
I am traveling currently,but I do have some info to share. I will report back!
I'm nearly ready to pull the trigger on this Bilstein 5100 kit. I think 2.5/1.5 should work well for our needs, and I'm on the fence about going to 33s (285/17R17) or 35s on my Rock Warrior wheels. I'd love to go to 35s, but I think the 33s would be a little more practical (reduced weight, no need for a swingout tire carrier). If going with 285/70/R17s means no wheel spacers, then that seals the deal for me....
Any suggestions on the 1.5" rear spacer that I would need for this Bilstein setup?
Interesting. Not sure how this would stress the coil more? Its just like dropping the top of the bucket down 1.5 inches. The coil is still at the same height it was before. My buddy has been extremely happy with his after the spacers.I wouldn’t add add spacers. It adds more stress on the OEM Coils,and you’ll have rear end bounce.
I tried 5100’s on my Sequoia rear after putting on TRD Front Coils and noticed the rear bounced bad. This was with NO spacer,which I imagine would make it worse.
Here is another topic for reading
2013 Sequoia Toytec Boss Suspension Lift
Been a long time lurker in the site and have read many outstanding articles and post that helped me make a decision on what lift and tires to go with....www.tundras.com
@LINUS I'm kind of on a budget with this Sequoia build, so I'm very interested in your Tundra takeoffs. Sent you a PM. I'm hoping that setup could be dialed down to achieve a 3" lift on the front.
What would be a good option (keeping cost in mind) for the rear to get to 2" lift? Bilstein 5125s with OME 2864 coils?
I have followed this thread and others like it,on this topic for rear 2nd gen Sequoia suspension.@LINUS I'm kind of on a budget with this Sequoia build, so I'm very interested in your Tundra takeoffs. Sent you a PM. I'm hoping that setup could be dialed down to achieve a 3" lift on the front.
What did you end up doing? I have a 08 limited that I want to lift.@LINUS I'm kind of on a budget with this Sequoia build, so I'm very interested in your Tundra takeoffs. Sent you a PM. I'm hoping that setup could be dialed down to achieve a 3" lift on the front.
I've been furloughed for the last month and will be unemployed after tomorrow, so I kind of put it all on hold until I have an income stream again.What did you end up doing? I have a 08 limited that I want to lift.
With state unemployment and the extra $600 a week the fed is kicking in plus the stimulus, you may be better off... Sorry to hear about the job loss, but make sure you are doing your homework on what you are entitled toI've been furloughed for the last month and will be unemployed after tomorrow, so I kind of put it all on hold until I have an income stream again.
Thanks. I'm aware of the Federal $600/week and we're also taking advantage of mortgage and auto loan deferments, so we're stable for at least the next few months. I'm trying to use this time to spend extra time with family and get our house ready to rent in case my re-entry to the workforce requires us to relocate. We were super stressed at first, but we're actually ok with everything now that we have a plan in place and know that we're not at risk of losing any assets.With state unemployment and the extra $600 a week the fed is kicking in plus the stimulus, you may be better off... Sorry to hear about the job loss, but make sure you are doing your homework on what you are entitled to
