License plate/frame rubbing off paint on tailgate.
Vernon, BC
I randomly decided to pull off the dealership-branded license plate frames yesterday. When I pulled the rear one off, I found two spots where the frame had completely worn through the paint down to the bare metal. Both areas roughly 7mm x 2mm, and thankfully not showing any signs of rust.
The spots were immediately next to the two bolts which hold the license plate/frame in place. I cleaned everything up, dried it, and covered the bare metal with liquid electrical tape, as that was the only thing I had on hand. (It is waterproof, and can be cleanly peeled off down the line.) I then added strips of fairly thick felt on the back of the license plate, on both sides of each bolt hole, to act as a soft spacer between the tailgate and the license plate.
Has anyone else found this to be a problem? I've never seen this before... wondering whether the previous owner's license plate was not secured tightly enough, or whether mine was secured too tightly by the dealer...
I think of dealer license plate frames and decals like automotive acne. I request the dealer remove any and all of their blemishes prior to taking delivery (they sometimes “forget”) but I remove them immediately upon arrival at home...
Insofar as license plates themselves, I usually put some industrial grade felt pads on the back to avoid metal to metal contact...
or put some 3M double sided tape along with the screws to also prevent rattling (if you happen to have a sub woofer in the back lol)
+1 on rubber or felt pads. I prefer felt on the LC as plate sits flush to tailgate. Also, insert felt pads and drill them for the mounting screws to avoid rubbing at mounting location(s).
I put a few adhesive rubber pads on the tailgate. I was concerned that something on the plate would still rub on the paint, like sandpaper when it got dirt on it.
I used a couple of push-in plastic bumpers, sized to fit a 1/4" hole, maybe a bit bigger based on your state's plate.
The only tool needed is a bit of spit on your finger.
