LHD axles under RHD
mac
Crew Member
Wet Coast
Anyone done this or the other way around- RHD axles under a LHD?
I'm sure the rear is no biggy but the front req's modification.
I didn't think there was a difference.
:confused:
The front axle housing panhard and the steering arms are reversed, as is the frame.
Swap steering arms and build a new panhard bar mount for the axle are the obvious differences. The US market locked axles you bought will also have larger front and rear discs than the JDM ones which can cause problems if you have 15" wheels.
Yup, those were the differences I've noted. I'm gonna give it a whirl I think. The bigger brakes are a plus for me although I do have 15 inchers. My rims are aftermarket so they may clear but if they don't I'll try spacers- I'm running only a 10.5 tire so a wider stance could work.
I guess I better hang on to my old unlocked ones for while.
