Lesson learned and note to newbies
Chance of getting the lube on the pads. Likelyhood of the lube holding grit and other particles that would lead to build up of "gunk" that would interfere with the free movement of the pads and actually wind up creating problems that will not occur normally.
A SMALL bit of anti-seize in the holes in the caliper where the pins fit is not a bad idea if the rig is operated in adverse conditions. Make sure to wipe off any excess.
Mark...
I have always put a skin coat of silicone grease in the pins, skin being just enough to leave shine, no buildup. I find it reduces squeaks, makes cleanup easier next time, they don't stick in the caliper, it's never caused a dust buildup or any other problems. But it's not critical and will work ether way.
I agree, this issue sounds like stuck pistons.
I have to agree with bro and others here.
There are some fast rules here from one who has worked for years in the "biz".
NEVER shop for a "deal" on repairs or service.
ALWAYS avoid shops who advertise for customers.
These rules are founded in simple matters. If you are not qualified to do the work yourself, can you know if a "deal" is legit? If a shop has to advertise for customers, do you want to be one of them? The answer to both is NO!
One of the most common cop-outs in the biz is failing to clean and lube the caliper slides during a brake job. The tech is paid 1 hour to put brake pads in. that is all that he does and he can do it in 10 minutes. To lube the sliders takes another 15 minutes. Some will not do it. As an old tech, I could shoot them!
If you want to find a good mechanic, you need to do your homework. The time to find him is not when you have a problem.
An oil change is a good time. Do not go to Walmart or Quick-lube. Interview a qualified mechanic instead. You need a good guy to look over your machine every 3000 miles.
When you interview him do not be afraid to ask a lot of questions. You need to understand his attitude toward his business. His business is your employee.
A really good mechanic is a rare breed. He knows that he needs to get the most miles from your car for the lowest cost. He looks for a long-term client over the quick buck. He knows that you both lose money if you buy a new car. It is in the best interest of both of you for him to keep your current truck in top condition at the lowest possible cost.
If that is not his main goal, then keep looking.
