Has anyone here accomplished this feat?
Doing the tear down of my project FJ40 I discovered some serious rust in the panel that runs behind seats. The body looked good until I removed the factory tool box, the rear panel was completely rusted out including the body mount area. It seems water had found a way in the channel and caused all kinds of damage. Anyways in order for me to fix this I had to separate the body from behind the door posts and drill out the spot welds running along the bottom seam. Once apart, the rust was worse than I thought, but still repairable.
Looking at the body pieces, I began to visualize converting the front body into a cab, sort of resembing a FJ45 P/U. To do this would probably cost the came as fixing the rear part of the tub.
Looking at where the visualized FJ40/45 hybrid tub would sit, I noticed it would be more benifical to lenghten the frame. By doing this I could easily have room to fab a flat bed for the back, improve rear driveshaft length, and have room for a doubler. What do you think, wild idea or what......
