- Vehicle Model
- 80 Series
OEM Toyota winches for 7x/8x Series Landcruiser (HZJ75, HDJ80, etc.)
Two OEM Toyota winches, OEM Remotes, and OEM Winch Remote Bags. I acquired these from another collector. The 12V winch had a bad drum (the steel winch line came off, and bent the drum, along with the washer spacer, common problem I hear.) I since swapped over the drum from the 24V to get the 12V winch closer to functioning. I also ordered a new OEM O-Ring from Japan, for the 12V motor. (Already installed.) Originally the 12V was going to go on my 80. I am a big fan of the OEM stuff. However, a nice Warn M12000 popped up locally for cheap, so I no longer want to pursue trying to get this mounted on my truck. I honestly just want this stuff gone so I can have some space back.
PRICE $1500 OBO
What’s included:
-One 24V Motor w/ cover & hardware
-One 12V Motor w/ cover & hardware
-One 12V Motor REMOTE harness
-Two Winch plates
-One 7x series Frame Mounting Plate & hardware
-One OEM winch solenoid (NLA from Toyota)
-One OEM winch hook
-Two OEM Clutches
-Two OEM Winch Housings w/ ALL internals
-One OEM Factory Service Manual
-One Used OEM Winch Remote & bag
-One NEW OEM Winch Remote & bag
What’s needed:
-Drum spacer washer ONLY for the 12V winch. (You can use a generic washer it will function just fine.)
-Cables from battery to winch
-Winch line
-Cool truck to put it on
Everything else is there to make a complete unit.
PRICE $1500 OBO
What’s included:
-Two Winch plates
-One OEM winch hook
-Two OEM Clutches
What’s needed:
-Winch line
