LED wiring converter issues
Diamond Valley, Nevada
I was helping my buddy wire some LED stop/turn/tails on his H**p the other day and ran into a problem I did not encounter on my 40
His trailer converter was from NAPA - Hoppy brand name, 5 wires in, 4 wires out -
Blinkers and brake lights will not work, tails work fine -
Instructions say that "red" brake wire needs to be hooked to the ground in order for the blinkers to work - sure enough, with the red and white wires tied together, blinkers do in fact work
How the hell are the brakes supposed to work with the wire tied into the ground?
If the brake wire is tied to the turns, won't the power feed back through the blinker and basically blink both lights via the brake power wire?
Why doesn't this one work and the same project I tried worked perfect? WTF??
Oh, and I've searched and searched and thanks helocat et al. for good info on the mod - can't find answers to this one.
Any part # for the converter that actually works?
Thanks
Umm, cuz its a Heep?
The heeps I have seen are 4 wire and don't need a converter.
What do you mean don't work? Don't light or don't blink.
Thanks
This doesn't make sense if you are referring to the chassis brake wire and a chassis ground.
If you are talking about the chassis wires, yes.
