LED interior lights: cheap add-on
Socal
I picked these up at costco, they are led batt operated lights (lasts 10000hrs)
simple and you can mount at the 3rd row belt bolts- you do need to fab a simple bracket but that's easy. it has a mounting tab built into the back.
i think it will help at camp. the light tube rotates to direct light, they are bright. the on/off is that little silver button.
I got the round ones and screwed them to the speaker grills above the third row. Pretty handy so far.
I also put on on the lift gate for directing light to the tailgate, but I broke that one.....
I had those round ones on the hatch for about a year until last summer, they got too hot and the velcro melted, then they fell off. I then screwed them on but those ended up stripping out, probably from the force of closing the hatch all the time.
Thanks for the tip FirstToy, I picked up a set of these new ones today and like them a lot better. For one I like the little button switch instead of pushing the light, and it's cool how they twist to aim. I popped the plastic panel off then drilled through it, then hid a washer and nut in there using a little 6-32 screw. I'm hopeful this outlasts the last set, and it's nice being able to see what's on the tailgate again.
