LED Flasher Relay?
VA
Does anyone know of a 24V LED capable flasher relay that drops into 70 series Toyotas?
I replaced the tail light and turn signal bulbs on my euro-spec HZJ73 with LED ones (long story), and now they're hyper flashing. I know I can vampire tap external resistors to increase the load back to stock, but that seems hacky to me and I'd like to avoid it.
From reading the wiring diagram, it seems that Toyota's flasher pins are the opposite of conventional flashers which makes things a little more complicated. I ordered a Tridon EG23 on the recommendation of another forum, and made a jumper harness to switch the pins, but it blows the fuse instantly so I'm thinking the EG23 was either defective or just isn't compatible period.
Does anyone know of another flasher relay that might work?
Odd Iron Off Road can probably help.
