LED Dash Lights issue
Los Angeles, California
Hey Guys, any suggestions for this ?
I've replaced all the major lights in my dash with LED's . I got all the shifter lights working and the entire right side of the cluster seems to be working, however the left side is still dark and the blinkers aren't working either. I've taken the bulbs out several times and flipped them 180 degrees with no luck either. The dimmer switch is connected and turned up. Pic below , thanks!
Any suggestions ? Bueller ? Bueller?
All combination meter illumination comes from the same source. I would start by removing the LEDs that you installed. Work backwards until you find the issue.
