Lean condition causing misfire?
Sugarhouse, UT
My 77' 2F cruiser has been consistently misfiring after driven for 5-10 mins around 40 mph. When idling cold it runs amazing, very consistent. starts up great. short trips are fine. acceleration is smooth up until that 5 min mark. afterwards misfire starts, the idle rpms raise 150-200 and engine runs really rough. starting from a stop at this point requires a bit more juice to keep from stalling and acceleration is rough until after 1/2 throttle where it smooths out and is fine. if left to idle for 5 mins or shut off. idle slowly returns to normal speed and smoothness. I am lost on what causes it but i fear its the carb
stock carb was rebuilt by a shady shop in SLC a year ago. tune up is recent. new cap,rotor,plugs, points, timing, dwell, idle speed, valves,PCV,K&N cleaned. I have a small exhaust leak at the flange that only occurs when warm but is quite small. Rig is desmogged.
Choke seems to help slightly with misfire but not idle speed.
Partially closing the choke would eliminate a lean condition. It should also make it idle at a higher speed (assuming the the choke idle cam screw is properly adjusted).
Describe what you mean by miss and the circumstances under which it occurs in more detail. Does it make a popping noise out of the carb? Does it do it at a particular RPM or under load, like acceleration or deceleration. Does it run fine w/o a miss at a particular RPM?
Which flange is the exhaust leaking from? If it is at the head, maybe the intake is leaking too. Have you checked for vacuum leaks?
What I meant by the choke helping is when partially pulled out it makes the acceleration more smooth. Nothing is popping at the carb end. The enging just sounds like it runs rough. It occurs at lower rpms and smooths out as they rise. I just can't figure out why this only occurs after its been driven hard and not while idling or after having sat at a light for a few mins. decel and accel both are rough until it settles down. exhaust seems to smell worse too.
After the shop
So I just picked it up today from the carb shop here in town. They found some interesting things. First that my dizzy was shot. it had so much wobble that they were suprised it started let alone ran. I replaced that with one that was a lot better and now it runs a lot smoother but I still get little pops as I drive. The shop notified me that there was a leak where the intake manifold meets the block. They found this by the starter fluid method. I had the intake manifold replaced 5 yrs ago and when this was done the intake/exhuast manifolds were machined. To fix my problem could I just get a new gasket and some RTV and just take it off and put it back on and just make sure its seated correctly? I don't want to have it re-machined and want to make it as painless as possible. Any suggestions?
