Leaky Rear Hatch - Need Help with Install
@ppc if I were to find a gap with the paper method, what would you assume needs to be done in said area?
Could be a number of solutions depending on where, how many spots you find. As an example on the lower gate bottom edge using a straight edge will confirm how bowed-in that area could be. Other areas may be the rubber was not hitting the correct surface squarely.
