Leaking Steering box and pump? Recommendations?
SE Asia
I noticed a small puddle under the truck today. I've been keeping an eye on my steering box as a noticed some extra grime there recently. Well it is quite a bit worse today. But the puddle looked like it is coming from a slightly different location. It's hard for me to see, but it looks like the steering pump is also extra grimy, and that's where the drips are from. I'm crawling under if I have time tomorrow.
Are the box and pump rebuildable? Is this a common issue? Or do I need to replace them straight kit?
Now, my LC is actually a HZJ105 (99 manual) but posting in the 80's section is always more helpful it seems. I'm living in Asia, and this is a Dubai spec cruiser. So I'll be importing whatever I need, as its junkyards and cheap knockoff parts here. So I'd like to fix this as best as I can, so I don't have more issues on down the line. Bring parts over is easy, but I do have to worry about weight, as they are in checked luggage.
Let me know if I can provide any more info!
Clean and check your low pressure lines first as inkpot is correct, they get old and leak. The try tightening that fitting on the hard line that goes into the gearbox. Don't put to much pressure on it, but just see if it will tighten up a bit as that may be the source of your leaks. Rebuild kits are available and much cheaper than buying new.
