leaking seal diagnosis
jfz80
Looking for a 🐷
Madison NC
So a quick little warm up run for next weekend yields this. Anyone want to confirm my suspicions that this would be the oil seal behind the companion flange leaking??? thus leading to the ineviteable? how many :banana: for this one. Definately dont want to drop 300 like another member did for his front leaking flange seal. ive got access to a seal puller for the front axle service, will this work in this application as well?
backup info: trying to climb a ledge, slid to the side and came to rest on the flange/sleeve yoke, had obvious weight on this location(but not supporting entire weight of truck), stacked a rock and backed out. drove 100 miles more and parked overnight w/ no leak. went to bank and back (ten miles) and started leaking this afternoon. u-joints feel good (no play) while installed.
thanks in advance
J, on my front seal leak it was actually where the entire third member "chunk" bolts to the diff/axle housing.
And that's not a result of bad spotting, just needed bigger tires.
I've repaired this on both my axles. I did however do it wrong, but it is almost 60k since so I think it's fine.
What I did was to count the number of exposed threads at the nut. Then back out the nut, remove the flange, change the gasket, replace the flange and then replace the nut in the exact spot from which it came by counting the exposed threads and aligning the stake mark on the nut.
As I said, technically wrong but it has been fine for all those miles.
Thanks tank- so this was the oil seal behind the flange.
Any other thoughts ??? driven very little since this occured and leak doesn't seem any worse, has yet to drop on the drive ( probably shouldn't have said that). I do have a slight vibe at 40-45 that wasnt noticed before, but seem to have all the weights on the shaft along w/ a nice candystripe.
Anyone think i might need to look deeper than the seal (oil slinger, bearings)
SST's- obviously im not buyin em all or it negates the DIY part
- how is the companion flange joined (threaded/pressed) it think thats the
only one i NEED
and lastly adjusting the drive pinion preload--- any words of wisdom/caution
dont want to mess anything up here in the drivetrain, i understand not
to over tighten or im goin all the way back down to bearing spacer,
but can anyone explain better to me exactly what the backlash is that
you are measuring in lamens terms. is it simply the pressure against
the gears as you turn the shaft and the wheels are not allowed to move?
thanks guys
ok ok so a bit more searching and ive found my answers to measuring backlash, but it seems there are varying opinions of whether this is necessary if you are only replacing the seal. either way i understand how now so not a problem, might as well check. any homade sst's for companion flange removal?
