For the last few weeks I have been monitoring a slow leak of antifreeze that has been accumulating in a crusty form on the side of the block just below the oil filter - near the block drain. I had assumed it was the PHH and went in to replace this last weekend, however as it turns out the coolent is slowly seeping from one of the the freeze plugs. I know these are pressed in from the factory - so my question is how hard is it to relace one of these and could this plug eventually fail complely leading to rapid coolent loss?
After searching - freeze plugs, core plugs and soft plugs I have found no info or previous threads on this topic.
Thanks,
nate
Thanks,
nate
. This crack is so fine I couldn't see / feel it out side under the truck.
