Leaking Drain Plug
Crescent City, California
A few weeks ago I posted regarding my needing to re-tap the drain plug thread on the tranny pan. Seems my treads are a bit too loose for the bolt and on a second oil change plug will not tighten up enough to seal washer and there is a slow leak. Until I can get a new pan is there a fix, a glue, a thread tape like plumbers use to hold the plug tight?
I'm surprised there is not a no thread plug available, like a rubber plug with a tightening screw but I have not been able to find one.
It's a plumbing item. Check your local hardware stores.
-Spike
A new plug and some Locktight thread sealer and a soft washer did the trick. Just a note in case anyone picked up Mon photogoods advice - Teflon is dissolved by ATF.
A new plug and some Locktight thread sealer and a soft washer did the trick. Just a note in case anyone picked up on Photogood's advice - Teflon is dissolved by ATF.
you may need a new pan. Sometimes the threaded bung, which is spot-welded to the pan, breaks loose and that is why they leak. I have seen this on more than one 343 pan. I have not seen it on a 440 or 442 pan.
aHA! Yet ANOTHER reason the older tranny rules the roost!
-Spike (The 343 is the newer one, right? Right?)
MH_Stevens said:
...Teflon is dissolved by ATF.
Where did you pick up that? Teflon is very resistant to most solvents and hydrocarbons.
I didn't "pick it up". I found out when I tried it!
Went all slimy and sticky and was disolving.
