Leaking brake line
So. Cal
Can you guys tell me what this brake line is called, or have a part #? I found my brake light on and found that I was low on brake fluid. The line going to my caliper is fine, but I found fluid leaking from this line. Any info would be appreciated
It appears to be the rubber drop line for the rear? I would invest some braided stainless steel replacements from SLEE
Looked it up for you on www.toyotapartsoverstock.com says it is no longer available, maybe through a dealer. PN: 9694033406 or 9094702933 Hose Flexible (for rear brake tube)
Sure looks like the line coming off the frame to the union on the front axle. Call around to your local hydraulic shops until you find one that makes brake lines. Have them build that line, the male line nuts are m10x1.0 inverted flare. Take to a shop to replace line and bleed system.
Closer inspection leads me to believe you're correct about it being the front.
you can buy replacement brake hoses from any parts store for $20. if you're at stock height or small lift the stock replacement hose will work just fine
