Leaking brake line help!
Yakima, WA
I’m putting my 74 40 back together with new SS brake lines.
This has been a great process of blowing this truck apart and rebuilding with a new dual diaphragm booster and 80 master from City Racer but this fitting is killing me. The only thing holding me back from firing it up and getting it rolling(so far) is this elbow.
At some point the top threads got crossed, so I got a 10x1.0 tap and chased them. I thoroughly cleaned out any metal shavings. I checked that the flares were not nicked or damaged. I tried pipe tape. I cranked them down as tight as I felt I could(too tight?)
I looked for a replacement fitting but only found some brass eBay fittings that I don’t think will work, and would prefer the Toyota one.
I’m not sure where to go from here. Anyone out there have a replacement I could buy? Or is there something I could do to tighten up the fitting I have? Should I cut off the flare and redo it even though I think it looks ok? And it’s SS, I heard it’s tough to get right.
Look here, at Federal Hill Trading Company, they have every brake line fitting, union, and coupler imaginable.
I think those flare nuts are too short. Some the toyota fittings on the axle housings need long flare nuts to fully seat. Is there any movement in the line after they are bottomed out? Measure the threads on the flare nuts then measure the depth of the fittings you are threading into. You should still have a couple of threads revealed when the nuts are tight.
