Leaking axle
noticed that I have got a bit of a leak from my axle inside the brake drum. (see pic). not sure if it is grease or grease/gear oil combo, wasn't really sure what is in this part.
also, possibly related, the bolts on my hubs have worked their way loose twice now (over 6-8mo), they seem to fit kind of sloppy. indication of??
my thought from searches is that either I need to redo the axle seals, or find and open up the diff breather, or both.
finally, anyone got a removal/service link for warn hubs, (or is it dead easy)
I'm not sure what you mean about the diff breather but if the diff breather is clogged then the pressure will release at the weakest point(seals). It is a good idea to replace or check the breather but that is not your only problem, and will not fix leaks. Unclogging the diff breather will only save you from messing up another seal after you replaced the leaky one. You might want to metion which vehicle and production date. This may help http://www.birfield.com/
I would bet that you have an inner axle seal leaking, and that when you remove the lock out, you will find a gear oil/grease combo in there. If you remove the wheel hub and bearings, you will also find it in there...
If you decide to not replace this seal and continue to run it this way, eventually, you will get this mess on your drum brakes, and they will stop working properly.
A frontendectomy is in your future! Get the FSM and get after it. It is a messy, time consuming task, but very doable!
Been covered out here a bunch!
Good luck!
-Steve
Are the lockouts aluminum bodied Warns?
If the bolts have been loose for a while the bolt and pin holes are probably egg shaped. It will be hard to keep them tight even with Loctite. You might have to replace the lockout bodies or upgrade to Aisin steel bodied lockouts with cone washers.
Poser said:
When you upgrade the front axle to disc brakes.... ;)
which is exactly the point, I have a disc brake axle to drop in when I get a few parts and get around to doing it, but in the meantime I was sort of thinking that if I just kept an eye on the fluid level in the diff, I could probably just keep running it for a month or two. there was a bit of oily goo in the brake drum area, not on the pads, but just a little, not like it was all coated.
yes they are AL bodied warns I read around a bit about this whole ovaling of the holes thing, I haven't taken them right off yet, but I took out the bolts and pulled it back a bit, and I am just seeing bolts, no pins. seems like I will need to find out a bit more about getting these things off, (and find my allen keys)
oh, 1975 fj40, sorry, I'm going to go figure out how to get a sig line right now
thanks
Once you get the dial face off you'll want a good snap ring pliers to take the snap ring off the end of the axle - Snap-On P/N SRP3 or SPR4 or equivalent:
