LEAKING 4-SPEED!
Austin, TX
I'VE SPRUNG A LEAK! Under my transmission right on the back end where the transfer case connects! Found after finding I was pretty freaking dry and pretty freaking hot on my transmission! I was pumping the 2nd quart in and THERE SHE BLOWS! I just got myself a gasket kit from SOR and looking forward into figuring this mess out for sure!
Thats my drain plug on the right for reference!
Check the transfer case to see if it is overfull. The seal between the transmission and transfer case can fail and fluid can overfill the case and run out the vent. Common problem.
There are hose kits you can make or buy that connect the transmission and transfer cases fill holes. This allows the fluid in both caes to reach a semi normal, but not correct level. I consider the hoses a temp fix until a new seal can be installed, but many have run the hoses for years!
Hope a bad seal is your problem.
usually the oil transfers into the transmission not into the transfer case. the fill plug is higher on the transmission that's why it drains back into the transfer. if the level was even with the transmission the transfer would be very over full.
as for the original post, is it leaking at the gasket between the extension housing or out the bolt thread?
what is on the end of the bolt? it should be sticking thru similar to the bolt at 6 o clock in your pic above.
I looks as if the seal is what is leaking not the bolt. But I couldn't tell when it began. Its not sticking through as much as I would like it to of course but it doenst seem to be the issue.
