Leak diagnos help
California
is this leak from transmission or something else?
I think that is how mine looks. Folks keep telling me about the upper oil pan arch seal. I then search some threads and realize it isn't something I want to deal with right now. So I keep some card board under my truck and keep feeding it oil and doing regular oil changes.
This isn't the "RIGHT" solution, but these things are 22+ years old and I could spend a lot of time chasing leaks.
^me too.
If it's red, it's the transmission. If not, it's the engine.
After looking at your photos, If that's all the more it's leaking I'd live with it. Once you find out how much work it is to remove the upper pan, to apply new FIPG, I'm sure you'll agree that you'll be more them happy to live with that little leak too.
Mine is leaking too. How much labor involved for something like this and what parts needed? Thanks.
Well, if its the rear main seal which looks likely and is my issue as well either the motor or the trans has to come. id wager $10 seal and 5-600 in labor at a minimum.
Clean it up and see if you can determin if upper oil pan arch
Mine is leaking too. How much labor involved for something like this and what parts needed? Thanks. View attachment 1727941
is your upper pan leaking anywhere else? I put some seal sweller in my oil for a few thousand miles and it didn't slow the leak, so would assume the rear main is good. my upper pan needs a re-sealing all the way around. I haven't bothered with looking with a mirror under the cap. It doesn't bother me much right now.
