If you plan on cleaning it up you can run a little non-flux core wire without welding gas around it, that oughta superheat it. That or a big ass rose bud.
It has been a long time since physical chemistry, but lead will not break down from hydrochloric or sulfuric acid, but does from nitric or acetic acid. Also, when heated with nitrates of alkali metals it forms salts, some of which are water soluble. Use of any of these chemicals, nitric acid, glacial acetic acid, or heated nitrates isn't the safest so your heating method is probably your only method.
