LCD screen repair/fix help
Naples
Hi everyone,
I was hoping someone could guide me in the right direction. My ‘01 nav screen w/ climate control has deteriorated and is hard to see now. I’d like to repair it before I sell. I just want an OE like solution and am not looking to upgrade the whole head unit.
I searched a bunch of threads and found it may be possible to just replace the screen. Has someone else done this fix and could help? Would something like this work? Thanks!
I replaced mine in a 2002 but be forewarned, it was a very daunting operation, and I consider myself very mechanically inclined. The entire radio unit has to be dissasembled to get to the screws to remove the screen. Lots of brackets, tiny screws, and hard to get to plugs. It's doable, dont get me wrong, just not as easy as "swapping out a screen".
Also, the results were not entirely gratifying either. The new screen is way less contrasty and nowhere near as nice to view as the oem one.
Thanks for your feedback. Do you happen to have pictures of what the display looks like now?
I tried taking a picture today but couldn't get one that showed the color and contrast with any accuracy.
I have the screen settings at full contrast and full brightness and the rich brown appearance of the oem is a grayish brown on this screen. With settings at any less contrast or brightness it just gets more gray and washed out looking. The map screen with it's colors looks fine, though, although I never use it anyway.
Don't get me wrong, it is a load better than the crazed screen I replaced, just a little bit of a let down, but still glad I replaced it because the old one looked like crap, lol.
Good luck if you decide to tackle it.
I think I took pics of the dissasembled componants while I had it apart. I'll check and post them if you are interested.
I am having the exact same issue and looking to replace the LCD too, were you able to replace the LCD? TIA.
I bought a LCD off AliExpress and swapped out the screen about 3 years ago. I work in IT as a living, spent a lot of times disassembling laptops back in the day, so it wasn't TOO hard.
Do I remember anything? Not really. Once you get in there, logic will have to take over.
I found a few in AE but it says without touch screen which puzzle me a bit. So if we replace the LCD, we no longer can use the touch screen?
I have no idea what you're looking at. Don't buy it. The one I bought is no longer available, but it was 90 bucks 3 years ago.
"TFD70W20 NML75-8399-113" is what I bought for my 2002 LX470 with ML. My original OEM screen only worked on 25% of the surface, I replaced the LCD screen and immediately regained the ability to use touch screen functions again, 100%.
