LCA / length
Sierra Vista, AZ
Currently running All Pro LCAs on my 07 fjc. Pinion is pointed a bit high. Looking for a measurement of stock LCAs. Center eye to eye so that I can adjust the All Pros. If someone has a different method let me know. Thanks,
I'd first ask...why is the pinion "pointed high"? Do you have a lift or have you changed the rear springs?
I'm sure you know that the rear pinion and t-case flanges should be parallel, that is the measurment I'd go by rather than the stock LCA length.
I measured my take-offs at 26 7/8" for reference...
Thanks Jerry. Have a 4" lift and 35s. Pinion and T-case are "close" to parallel. Been this way since I re-geared in '09. Have recently developed a vibration in the drive train and am searching.
Have your tires re-balanced and look closely at your u-joints for wear.
