LC80 1FZ-FE timing problem
Again, I'm not familiar with that engine, but most ECU's have some variety of feedback/feedforward, try unhooking the battery, leave it de powered for 10 minutes or so, long enough to leak any capacitive charge.
how many degree's off is the timing, what does the FSM say is correct? if you can't find a correct timing setting within @ 6 degree's, you are probably off a tooth timing gear, if everything else is correct.
by timing gear you mean timing chain mechanism / compression timing?
EDIT: FSM states ignition timing to be 3 deg BTDC
this vehicle doesn't idle stable at 3 degrees but at around 16 degrees.
The compression timing is spot on and the timing chain has no slack
at TDC cylinder 1, crank pulley pointing at 0 - cam pulleys single dots align in a straight next to each other and two dot marks on the opposite sides.. just as the FSM states
http://ww2.justanswer.com/uploads/NewKid08/2009-09-30_144050_Camshaft97LandCruiserFig02.jpg
Yes - it was the timing chain not installed correctly - the mechanic at that time who checked and confirmed that the timing was ok, was wrong.
timing chain was installed and the engine was timed correctly - it ran very nicely afterward.
after some time its ECU malfunctioned (leaking caps), which was then replaced and its performance got even better.
pls explain your problem in detail maybe we can help
how did you determine the ECU malfunctioned (the leaking caps?), did you get an error code?
