LC300 GR
australia
Help, which tire size is much better suited for LC300GRS without lift. 275/70 r18 or 285/65 r18. Pros and cons. Thank you for the advice.
I'd expect a 275/70/18 will fit on the stock wheels without issue; It's a good size tire and I ran that on my 200 for the last ten years.
275/70/18 should be fine on OEM setup
The 285 is about 1 inch taller, the 275 is about 1.5 inch taller. The width is different on both.
Both only have a few selections in Passenger rating and can push you into LT rating which is heavier.
I would run the 285/65 in yokohama x-at or Michelin defender.
