Angelo1
So far, so good. I'm going on a trip next week through France and give her a proper run.
Share some scenic pics as well.
Share some scenic pics as well.![]()
had to return the temporary license plates, so can't driver her out of my garage until i receive the new ones (tomorrow/Monday). will get some nice pics and post
LCKID>>> those 305's look great ! congrats !more pics
Anyone have details on what advantage(s), besides a wider track, one would gain from addition of Spidertrax wheel spacers on a 200? My thoughts are that the look alone may be worth it but I'd really like to know if they give additional clearance for larger tires w/o a lift.
I've got spacers on mine. They are fine at 120+. Sparks Trd put them on.
LCKID what size did you go with on the spacers?
I recently wrote to SLEE and this is what he had to say w.r.t. spacers :
"I would only recommend spacers if you have a specific need for them. When you lift the front end of the truck, you are losing track width, so some people put them on the front only. Spidertrax 1.25" will fit the TRD wheels as they are standard M14"
which spacer make are you using? width?
I am looking at adding the 1.25" spacers to help clear the King Shock remote reservoir on the driver's front. The tires currently rub slightly at full lock. I am running Toyo AT II 285/65R18 on stock rims and would like the option of running snow chains. Has anyone else had success running chains with a similar set up? If I tried to run chains today they would chew into the remote reservoir. Thank you in advance.
I have a brand new set of spacers from Slee. pM me if you're interested.
Any idea why they only call for rear chains?
In attempt not to hijack this thread, am offering a tangential bridge to a similar, but different discussion on a related thread...
If anyone on this thread can offer insight into being able to run 9/32 to 3/8 chains up front on a stock height rig with 285/65R18 or 275/70R18 tires after installing the spidertrax spacers, your input in response to my post in the below thread would be appreciated.
Tire Chains on a 200 Series?
@lgop - this may be aligned to your question above.
Thanks!
