LC 250 Parts Thread
Body Moldings Accessory Part Number
Numbers in parentheses are the color codes.
PT29A-60240-35 (202)
PT29A-60240-37 (4V8)
PT29A-60240-32 (1L7)
PT29A-60240-33 (2ZC)
PT29A-60240-31 (089)
PT29A-60240-34 (2ZD)
PT29A-60240-30 (040)
Living in the US, I would love to seenif possible to purchased badges for the LC 250 that are sold in international markets, specifically the "Prado" and "Turbo" badges seen in the Middle Eastern markets. Can anyone help tracking these down. There are múltiple photos in these forums of these particular versiones with their badges and TBH I rather have those badges they the "I Force Max" eyes sore
What are the part numbers for the black version from the 1958 for the 2 rear bumper valance pieces on either side of the hitch. And the black version of the front lower bumper valance?
Copying over the parts number that I saw from another post on the running boards from the mid-tier/LC trim.
With Courtesy Lamp:
51083-60280 RH
51084-60280 LH
Without Courtesy Lamp:
51083-60290 RH
51084-60290 LH
Same..I want that Prado badge stat lol. I emailed a Toyota dealer in South Africa to see if I can get a part number sent over. If I hear back I will keep you posted.
Request: I am looking for the part number for the factory weld-nut clips/plugs for Predator Step delete. I think there are 6-8 per side? Perhaps a M8 bolt?
I understand there are threads on other Toyota forums, and perhaps the part is the same (as well as suggestions to just teflon tape the bolts and reinstall).
However - I would just like to confirm the part # from a LC250 part schematic. Thanks!
Is there any word on if headlights are interchangeable between trims? Can you swap the circular 1958 headlights for the rectangular LC ones?
Requesting part numbers:
These parts of the front bumper. Do they come painted? Does the 1958 have a different part number?
This style front spoiler. Maybe they’re not available in NA.
This style mud flaps. Maybe they’re not available in NA.
Thanks!
I have a 1958 with the factory roof rack installed...I noticed that the cross bars have a channel in them, along the upper side which is empty. It seems to be unfinished and could be a problem for mounting a ski box...where there will be two hard surfaces meeting. Trying to avoid rattles and other noises.
Does anyone know if there is a rubber molding that is available to slide into these "tracks"?
Engine air filter: 17801-31180
Alternate Oil Filter. Just finished my first oil change with Toyota 0W-20 Synthetic and Toyota oil filter...90915-YZZN1.
The correct replacement oil filter is super small...about the smallest I've seen on an automobile. There is room for a taller one ...but not sure about the correct part number.
Does anyone know if there is another, bigger filter, in the Toyota filter lineup that would fit?
I have the GX factory roof rack. FYI, I had to drill new holes to move some of the cross bars to accomodate my Thule XL box. The car sounded better with the box on and i did not use any rubber to dampen anything. How is the wind noise with the factory roof rack on the LC? the LX is horrendous.
