Last spark on drivers side stuck
austin
Was going to swap the plugs and coils and they all came out pretty easily.
Now working on the drivers side up against the fire wall and I can’t get it to come out. It started and I’ve got a few revolutions on it but now it’s stuck. Can’t tighten it or loosen it.
multiple e squirts of pb blaster not helping.
I may be screwed as this is my only transportation.
I experienced the same problem, same plug, just a few weeks ago. Let it soak in penetrating oil and be patient. Mine came loose after 4 days soaking and moving it a bit at a time. Good luck!
Got that ****er out. Had to use the 1/2 breaker bar to get it past the snug spot. Is there anything I should do when screwing in the plug?
Run a tap through the hole?
