Hi everybody, I really like this board, it's the best one Ive seen yet. I have just purchesed my first LC, coming from a strong run with Junk, I mean Jeep....typo
I Have a question though- what is the largest tire size that I can fit on my 1999 LC ? I have searched around here and have found 275/70 16 is the metric size for 31.2" Will 33's fit and not rub? I will also be using the stock rims.
#2 - Boy- the key programing issue really seems to get the ole blood pressure going. There are many posts about this, my problem is as follows: I have 2 keys, both with the built in remote lock/unlock feature. Only one of those works. I followed the instructions of a previous post (ie insert key, remove, lock-unlock the doors 5 times ect ect). I get to the point where it says to push the lock key on the remote to be programed. The LC verifies that it recived a signal from it by cycling the locks. The instuction sheet says that "Programing is now complete" - but the key still doesn't function the locks. Am I doing something wrong? Doest the post have something missing?
09-23-04, 03:54 PM #9 Cruiser4UGA vbmenu_register("postmenu_227594", true);
IH8MUD Rookie
Ok here it goes.
1. Key not in ignition, drivers door open and unlocked.
2. Insert Key into igntition cylinder and pull out.
3. Within 40 secs, press lock and unlock 5 times. lock and unlock=1.
4. Close drivers door and open it.
5. Within 40 sec, press lock and unlock 5 times.
6. Insert key into ingnition cylinder
7. Turn key from lock to unlock 1 time (add mode)
8. If successful to this point doors will lock then unlock to confirm add mode.
9. Press the lock and unlock buttons on transmitter simultaneously for more than 1 sec.
10. Press any button on the transmitter.
11. If doors lock and unlock one time, success. Two times-start over.
Hope this does it for you.
Thanks in advance. Oh yea - I dont think I will ever buy another Jeep, not after this truck....
IH8MUD Rookie
Ok here it goes.
