Largest/best tire to install on stock LC 2010
For what it is worth, the above photos are Michelin LTX Defender LT285 65R 18 E’s on a stock truck with no lift.
Any thoughts from the group on how they would do off road and aired down? I run them at 42PSI for the road.
anyone try 305 60 r18 on stock everything? inch taller and inch wider i bet Yoda made for us :)
looks taller! gained about an inch of diameter which is .5" of clearance? That could easily make the difference in a tight spot.
I have searched (or perhaps I'm just lousy at searching) but I can't find the answer to fitment for BFG KO2s- 285 65 r20s on a stock '14 LX570.
Thanks
It looks like the fitment for that size would be similar to this....a 35" will clear thr body mount with a proper offset so a bit of trimming and heat molding if you're that ambitious...
