Landtank plate install
Sold my 3* caster bushings and need a little help with the TANK's plates.
How are you guys positioning your jackstands and keeping your axle from moving?
Damn. I really would like to help on this one since I'm one of the guys who has the plates installed.
I got in a time pinch and had a local suspension place install mine. I watched the last 20 minutes or so. Jack stands looked to be placed in the regular spots, just leave room to drill. Thats part of the deal with having a 90* angle drill. Rent one from Home Depot for $20/day if you dont have one. I dont think the axle will rotate, just jack it up enough to get the tires off and you'll be fine I think.
Hope some other guys with hands-on experience will chime in, but I think you'll find its very straight forward.
Would chocking my front tires where they cant move, putting truck in park, with emergency brake on be safe enough? I'm talking no jackstands. I'm thinking too risky.
I'm not sure if these plates normally come with instructions or not. Mostly I just need a safe way to detach the arms.
Place a floor jack under the pinion. That will keep it from going down. You can also use a ratchet strap to keep it from moving up. That's how I did mine. BTW, his plates kick a$$.
Yah chock the tires. jack the axle up and drop the frame and pinion on a jack stand. Then have fun drilling.
Just to clarify, you're saying down referring to back and up referring to forward right?
no he is talking about the suspension travel up and down i.e. the axles vertical movement.
didn't you get instructions with the return email? I send the confirmation info and instruction to the email address used in paypal. If not then send me another email and I'll get them out to you.
You basically get the axle up on stands but only remove one arm at a time so the axle is stable for drilling. Once the passenger side is drilled you install that arm and then do the drive side. It's important to keep that axle rigid so when you lean into the drill it doesnt move and drills straight.
:whoops: I didn't even see that email. I'll check it out and it should give me an idea of what to do now.
