Not from this area and am looking for a shop that works on LCs. I'm in Spokane, WA (Eastern WA next to Idaho). Yall know of any?
I know Parker Toyota would do a first rate job. Let me know if you go that route and I'll find out who's in and who'd do the best job.
BWR- do the tests for the HG you'll find here - bubbles in the overflow, etc. Also, a member here makes excellent new leather seat covers and also sells seat heater inserts for same if you're inclined.
DougM
Doug,
I've got a 95 80 series. I was told by a general mechanic that the head gasket had a slight leak--he prob knows less than I do about LCs. I also havent had the birfield specifically checked out. A few things I need done and plan to do (not urgently or tomorrow but plan to within 2010) if HG is leaking fix that, an OME lift, DS and PS leather seat bottom covers replaced, ARB Locker for rear, bumpers, etc. Thanks for your help.
Browning
Sounds good. Let me know who to talk to over there and I'll give them a call. I'll also hit up Bgndn to see about the other place. I have a buddy in Rathdrum I could go slum it with so it would be worth the drive.
Is Kurt at CruiserOutfitters.com still the best place to get the entire rebuild kit from?
PS - Ditto on not using Downtown Toyota. The service I've received from them was HORRIBLE.
Thanks. Yall know if some tundra seats would fit up front in the LC?
Well we are sorta local, but do drivetrain. So we can handle your arb lockers, gears, knuckles, birfs, ome suspension etc, but dont do engine work.
retrofit tundra seats.
