Land Cruiser 80 series OBD issue
Quetta
Hope all are fine
I have a Land Cruiser 80 series 1995 model 1fz fe the issue is that when car is having any sensor issues the engine check light doesn’t turn on even if i remove any sensor and start car drive no engine light
Note: when i turn on ignition CEL comes when car is start CEL turns off
When i short TE1 E1 the OD light flashes quickly mean no code engine light is Still no flash
Hope all are fine
I don't think you are shorting the proper pins. The OD light is related to transmission not the engine.
You most likely have shorted E1and TT
"To get transmission codes on a 1995 Land Cruiser (FZJ80), jump terminals E1 and TT in the diagnostic box under the hood using a paperclip, then count the flashes of the Overdrive (O/D) light on the dashboard"
i shorted Te1 e1 for engine codes but in my car the transmission od light is flashing
I want my engine check to work and show codes so i can repair sensors i am shorting correct pins
Can you show us a picture of your diagnostics port so we can verify?
Huh.
I'm stumped. @jonheld you got anything?
I think previous owner messed with the Wirring maybe because its abnormal and i saw from ecu all connections are good and oem no wire is change or damage
