SOLD Laguna Niguel, 2007 Toyota FJ Cruiser
Status
Not open for further replies.
San Juan Capistrano
Year
2007
  1. FJ Cruiser
Laguna Niguel, CA 92677 United States
Mileage
217500
Color
Silver
Up for sale is my 2007 Toyota FJ Cruiser. I've owned it for 3 years and it needed a new engine when I bought it in 2022.
MAJOR WORK I had a used 80,000 miles engine professionally installed at 182,500 miles, so the current engine has roughly 115k miles. I have all receipts for the work. It also came with new spark plugs and a T-Stat housing which was installed at the time. I've attached Blackstone Oil Analysis reports that I run regularly to make sure the engine is in working order.
Since then I've focused on restoring this to OEM+ status. It has:
SUSPENSION
1. Bilstein 5100 lifted at 2"
2. Bilstein rear lift springs at .9"
3. Moog LCA's
4. Freedom Offroad UCA's
5. OME 885 Front lift springs for the lift (not using spring perches)
6. New tire rod end links / cam bolts
ENGINE/FUEL
1. URD Fuel pump & External filter
2. New OEM Throttle Body done at 191k miles
BODY
1. All Pro Offroad Kick out Rock Sliders
2. Body mount has been chopped
WHEELS / TIRES
1. Qty. 5 Toyota TRD Wheels
2. Falken Wildpeak AT4s (Installed at 201k miles) with matching spare, properly rotated in when doing rotations.
3. 2 new front wheel bearings done at 199k miles.
4. Centric brake rotors, 2 new front calipers, and set of front pads done at 196k (Akebono pads)
INTERIOR:
1. New leather wrapped steering wheel
2. No seat tears
3. New Fan blower motor resistor
4. Bullet Point Mounting System dash mount for phone / 2 way radio (can remove if you would like)
5. Everything works
FLUIDS:
1. Rear Diff Fluid, Front Diff, Transfer Case @ 182k
2. Transmission Fluid Drain/Fill at 192k and again at 212k
The Bad:
1. Interior drivers armrest has a crack (photo'd)
2. Very minor dings or scratches but I think it's far less than you would find on any car this age.
3. Small crack in windshield on the bottom right passenger side from a stone. I don't think you can see it in the photos. It's so small and out of site so I haven't bothered to change the windshield.
4. Car spent some of its life in Minnesota and had some minor surface rust. I hand sanded it off and put some rust reformer on it. It came off easy and it only bothered me because I'm in CA and am used to cars with zero rust.
This FJ is one of the nicest examples of a 2007 you will find. It drives and tracks straight, steering is tight, there are no creaks or rattles. Only selling because I've moved on to a GX as my next project. Looking for get $12,600 OBO
Status
