knuckle soup consequences
reston virginia
I failed physics in highschool so explain it like i'm 5: i know it's bad but how bad is driving around with grease/diff oil mixed up and sucked into the differentials? is the car going to suddenly seize up and flip like in the movies? is something going to turn red hot and come off while driving at highway speeds?
i thank you in advance for shedding light on this matter.
Premature bearing / race wear, but premature wear, is wear. This + Time + Load + Brinelling + Improper Preload will = early fatigue failure.
If you can't or don't have the money to fix it, use the service port and add the correct grease into the knuckle and continue to watch the fluid in the differential as well... Remember that you also can get reverse contamination into the differential.
Cost of ownership my friend. Nothing lasts forever, especially without proper maintenance.
Good luck.
John-
No, even an RPG shot at the front of the truck won't make it flip or blow up like in the movies......
Having the lubricants mixed together shortens the life of the components. The birf's don't like the oil because it doesn't have the pressure properties of the grease and they will wear grooves in the birfs earlier in life than if they always had moly grease.
The diffs don't like the moly in the oil because it is "too slick" and the moly in the grease has a such a low coefficient of friction that bearings tend to SLIDE rather than ROLL, so they wear flat on one side instead of rolling.
Basically, get it rebuilt in a "timely" manner (a few thousand miles of easy driving) and put in the proper lubricants. Don't take it on a 5000 mile Expedition until it's taken care of.
Even when they do have a problem, it's usually an anti-climactic relieving of the smoke......Sometimes squealing, then breaking, locking up, and crying.
IMG_0429.webp IMG_0454.webp bearings could just melt together and all you hear is a little squeak. All i noticed was that the wheel was loose.
Drive it.
As long as you keep some type of lubricant(grease) till you have time/cash to repair.
Meh.
Drive it.
Any lube is better than no lube at all. :lol:
Yep, agree, kinda.:hillbilly: With considerations:
For the knuckles, gear oil is a good lube, may even be better than grease? But the seals are not designed for thin lube, so it runs out, makes a huge mess. If the level is low, pumping fresh moly into the knuckle will thicken it, depending in seal condition, may extend the time until reseal is critical.
Some moly grease isn't bad for the diff, if you study oil analysis, most contain moly additive. The problem is grease thickening the oil way out of grade. One of the major functions of the oil is cooling, it's in contact with the gears, etc, and the housing, transferring the heat out. When the oil becomes excessively thick, it tends to stick around the housing, leaving little in contact with the gears, carrier, etc. Have seen, repaired diffs where the gears, bearings, etc, were purple from this.
Obviously it's best to always have your stuff sealed up tight, at first sign of seepage immediately stop and overhaul. In some cases this isn't practical, as long as the lubes are somewhat close to what is needed, they can be driven, in most cases long distances, without component damage. One thing to remember, no matter how some talk about these things being made out of feathers and egg shells, they were designed and in some places used as utility vehicles. Worked way hard, often with little maintenance, and do it reliably, in other words, pretty darn durable!:hillbilly:
thank you all for the comments it all makes more sense now. there's a 80s series that's parked behind a gas station near me almost everyday. i think i might have gotten lucky and found myself a mechanic that's a LC owner. I'll go talk to him soon...
remember its 48 INCH pounds not 48 FOOT pounds on the bearing pre-load. But yah, lube is lube
