Does anyone know if a 1987 knuckle rebuild kit is the same as a 1994 knuckle rebuild kit? My mechanic seems to not know. Thanks y'all!
Ask these guys. That's where you'll want to get your parts. Kurt will get you straight.Does anyone know if a 1987 knuckle rebuild kit is the same as a 1994 knuckle rebuild kit? My mechanic seems to not know. Thanks y'all!
Thanks Onur! Very helpful info.No. They will not be compatible. The knuckles, axle shafts, spindles and birfields are larger.
The hub oil seal, lock nuts, lock tab washer, and thrust washer will work though, as well as wheel bearings.
Thanks! I'll check them out.Ask these guys. That's where you'll want to get your parts. Kurt will get you straight.
www.cruiseroutfitters.com
@cruiseroutfit
It's a bit scary if your mechanic can't ask the question and check it.
Thank you again for all your input. Very helpful!Let us know, we would love to help. You can read more about our kits here on Mud: Product Spotlight: Cruiser Outfitters Knuckle Rebuild Kits
