Just finished rebuilding knuckle on the passenger side yesterday (LX450, unlocked) and ran into an issue/question I didn't think about when taking things apart. I tried searching but didn't see anything mentioning this specifically. The hub spins fine without the hub flange installed, but when I install the hub flange, I noticed the wheel wouldn't spin. For reference, this is with just the one wheel up off the ground with the truck in 4H and park and the other 4 wheels on the ground. I can turn the wheel slightly and see the front drive shaft rotate slightly, which makes me think the end of the axle is seated properly, but the wheel will not rotate all the way around. Maybe I'm just paranoid.
At least one knuckle rebuild video (the 6th gear garage one, at about 10:00) shows the guy putting the vehicle in neutral so he can spin the birf to the position where the flat is on top, which makes me think maybe it's OK. I just don't want to mess the diff or anything up and thought I'd ask before taking the whole thing apart again to check my work. Thank you for the help!
) on the ground, to turn the raised wheel with the flange installed by hand, you would essentially drive the car forward by hand.
