Knuckle Problem?
So I was replacing the front tie rods on my FJ60. Really don't have many miles on it since I've owned it but 186k on it now. Planning on doing a knuckle rebuild and when I had the wheels off and all the linkages apart I was moving the wheels left and right and noticed a distinct settling spot on center with the wheels facing straight ahead like an extremely pitted bearing gets. Any ideas of what this might be?
What should I expect to find and should I order parts or start searching now for something other than the normal knuckle kit (w/o wheel bearings)?
thanks,
mike
Had to laugh. I remember back in the day when my buddy and I parted out our first spare parts rig together, we thought the Japanese had devised some sort of self-centering mechanism for the front end!
That is DEFINITELY a sign of worn knuckle bearings and/or races. This means you will notice a great improvement in steering responsiveness when you are done. Just that much more to look forward to (besides bonding with your truck!)
That is called an "indexed" bearing and it is not a good thing. You should try to ride a motorcycle with indexed steeringhead bearings. Waaahhooooo... what a ride!
Get a rebuild kit and a big bunch of rags. Oh, don't forget some cold beverages. ;)
It's funny, i've got everything almost reinstalled (just going to get the rotors turned tomorrow) and I didn't notice any real large pits, for that matter didn't notice any pits. All the knuckle races are pretty smooth, making me wonder what's going on. Wheel bearings look pretty good too... Birfield issue? I had pretty consistent clicking in the front end in 2wd and 4wd. I was hoping it wasn't a birfield issue.
Any ideas?
-mike
Wow...Same thing here!
I'm rebuilding my front axle (thanks guys for help on my shim and tie rod ?'s) and also noticed both wheels "settle" into the centered position quite positively. I assumed it was a "feature!"
Knuckle kit on the way now, am also rebuilding.
When I spoke to Liquidoffroad.com, he said the wheel bearings are rarely worn/need replacing, most people just repack them. Sound right?
BTW, am quite PO'd with Liquid right now. Decided to try them for the first time and he 'forgot' to mention that the TRE kit I ordered was out of stock and he didn't bother to send the rest of my items, won't get them until next week (missing the weekend!)
Don't know if I'll order from him again.
John,
Rob (Liquid O.R.) gave you sound advice, wheel bearings rarely get bad, but if there is enough water in the knuckle, there is a chance the wheel bearings would be pitted or rusted too. Take it apart, clean them and see if there is any rust or pitting on the races.
My experience with Liquid has been very good. Bought a few times and the items always arrived on time or as promised. Just a human error I bet.
Dave
I just redid the knuckles on my FJ60, and since I was going to all that trouble, I replaced the wheelbearings as well. One side looked great, the other side was clearly worn. I figure at 190k they have done their duty, but I kept the good set in my cruiser for trail spares. I even kept the two top knuckle bearings sice they looked better than the bottoms and put them in the spares box-a poor man's knuckle kit for the trail. I doubt the clicking you hear is birfield related if you hear it in 2 wheel drive. Look at the shock mounts, spring bushings etc. There is nothing like new parts to give you that "new" feeling when you drive your old truck. My vote is to replace the wheelbearings if you can afford to. I used the Koyo kit from Marlin-good stuff at a good price.
I had the self center thing too-bicycle headsets get the same wear and get very scary to ride down hill.
Time warp! Here are a few pics of a ‘deferred maintenance ‘ front axle I am currently working on. 1977, never serviced except for putting new brake pads against the original rotors! Had to drill 10 of the 12 Allen head screws out of the hubs! Self centering feature:
There’s a knuckle in there somewhere :
Is it soup yet:
Cute the way the rollers just stayed put:
