Knuckle pre load question
Plain City, UT
Rebuilding my knuckles on FJ62. I used the same shim thickness top as bottom. Pre load is 7 lbs.
Two questions:
1. Is the pre load amount OK? I will be using 37 inch tires.
2. Can I assume that the knuckle is centered because I used the same thickness on both the top and the bottom or do I need to used the centering tool?
Thanks!
Kyle
Two questions:
Thanks!
Kyle
Use the same shim thickness that was on it assuming nobody already messed them up.
